Id like to figure out how to convert my .mkv files to avi, or mpeg, so that I can then get them on dvd. I have been doing .ogg and .ogm files fine using virtualdubmod then tmpgenc, but for some reason when I parse the file using dubmod, and then I demux the subtitles out, tmpgenc wont recognize it. Please someone help me figure out how to convert these!
Results 1 to 10 of 10
Yo, check this post so see if you could make it through. There are 2 of them (mine is the second (NightScream) so try them out).
https://www.videohelp.com/forum/viewtopic.php?p=1018674#1018674 -
This is the third time you've posted the same message, and it might seem rude to some.
Wouldn't you rather start a new thread? -
Why you guys get all mad or "rude" or something else? Let's help each other. PLEEEEASE! This is for everyone.!
Maybe i'm interpreting this differently than you;Originally Posted by NightScream
The forum rules are here;
https://www.videohelp.com/forum/viewtopic.php?t=124514 -
Yes that's true but when you go to search for a guide or a post to resolve your problem, you find things diferent than the one that you are looking for. So I made things a little bit easier. Now anyone who type the MKV to MPG on the search, will find the answer like in 1min, when before YOu had to read all the things sayd (like 30min or 2 days) to find some of it. See? E A S Y. . . Thanks.
Ahh, well thanks for the help!
THe reason why I had a second thread is because I wanted to describe it better and since I already typed the first one, I didnt know what to do =( -
Don't worry about it. If you need something from me you could ask in my Post,
https://www.videohelp.com/forum/viewtopic.php?t=235013&highlight=mkv+mpg
I'm here to help. -
After you make a new post a new button will appear.Originally Posted by Dains11
You can edit your post as much as you like.
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19 -
How to play MKV, MKV to AVI, MKV to DVD, MKV to Xbox 360 or Playstation 3
By Baldrick in forum Video ConversionReplies: 2Last Post: 8th Mar 2012, 03:45 -
Complete newbie help in converting DVDs to avi/mpeg/mkv
By damianjmcgrath in forum DVD RippingReplies: 8Last Post: 14th Jan 2012, 10:00 -
MKV (H264, Interlaced, and MPEG Audio) to AVI.
By flash_49 in forum Video ConversionReplies: 4Last Post: 1st Nov 2009, 12:19 -
Best conversion software for ScreenPlay Pro for mkv to mpeg 4 avi
By darkmantis in forum Video ConversionReplies: 0Last Post: 2nd May 2009, 05:43
