I have a Directv/Tivo (Philips 704). I have RCA cable going from it to Video Capture Card on my Computer. What is best software to use to pull a Video off Tivo and Convert to DVD format? I see there a Pinnacle Product and a Ulead one. Any thoughts or comments on the way to go?
Results 1 to 9 of 9
Find a guide.
Hard to give advice not knowing the capture card.
Try some of the capture info at digitalFAQ.comWant my help? Ask here! (not via PM!)
Hauppauge comes with it's own software that works fairly well for their cards.
Yes it does but I think have to then convert it to DVD format. I was wondering if there is a Program and Captures and convert at same time. I maybe wrong and I'll check what software came with this Tuner.
Thanks -
Hello,
If your saying what I think you are you have to AUTHOR any thing you capture. You get a mpeg or avi file after recording. You have to turn that into something a dvd player will understand (unless it plays mpg files, some do). This is called authoring and theres no way around it. It turns your mpeg into a video_ts folder with vobs in it.
OK...Thanks Yoda that was what I was talking about. I got all the programs I need to do what has to be done. I was just hoping that maybe there was one out I didn't know about that maybe did it all in 1 step.
Thanks again all -
Originally Posted by ukcat
accounting software for Mac bookkeeping software for Mac
By Noahtuck in forum Newbie / General discussionsReplies: 1Last Post: 30th May 2017, 13:43 -
Why does this movie playing software not work? (Bluray software)
By oz_surfer in forum Software PlayingReplies: 5Last Post: 31st May 2010, 03:18 -
EasyCap Video Capture Software - No Picture On Software Screen
By Teac23 in forum Capturing and VCRReplies: 2Last Post: 9th Nov 2009, 19:26 -
Developing software that uses opensource or GLP software
By wiseant in forum ProgrammingReplies: 4Last Post: 10th Sep 2009, 08:07 -
media server software to stream to my HTPC, What software works the best to
By onedeviantd in forum Media Center PC / MediaCentersReplies: 1Last Post: 27th Feb 2008, 21:45
