I've encoded a movie to SVCD format and a second audio track. The encoding process went well and i've got one .mpv and two .mp2 files. Unfortunatly i can't mux them for some reason. The process window says:
INFO: [mplex] mplex version 2.2.2 ($Date: 2003/05/13 20:27:15 $)
INFO: [mplex] File /Users/mrash/Desktop/COMICPARTY1/TITLE02-ANGLE1-VIDEO1.M2.m2v looks like an MPEG Video stream.
INFO: [mplex] File /Users/mrash/Desktop/COMICPARTY1/TITLE02-ANGLE1-AUDIO1.AC3.ff.mp2 looks like an MPEG Audio stream.
INFO: [mplex] File /Users/mrash/Desktop/COMICPARTY1/TITLE02-ANGLE1-AUDIO2.AC3.ff.mp2 looks like an MPEG Audio stream.
INFO: [mplex] Found 2 audio streams and 1 video streams
INFO: [mplex] Selecting generic MPEG2 output profile
INFO: [mplex] Multiplexing video program stream!
INFO: [mplex] Scanning for header info: Video stream e0 (/Users/mrash/Desktop/COMICPARTY1/TITLE02-ANGLE1-VIDEO1.M2.m2v)
INFO: [mplex] VIDEO STREAM: e0
INFO: [mplex] Frame width : 480
INFO: [mplex] Frame height : 480
INFO: [mplex] Aspect ratio : 4:3 display
INFO: [mplex] Picture rate : 29.970 frames/sec
INFO: [mplex] Bit rate : variable
INFO: [mplex] Vbv buffer size : 88064 bytes
INFO: [mplex] CSPF : 0
INFO: [mplex] Scanning for header info: Audio stream c0 (/Users/mrash/Desktop/COMICPARTY1/TITLE02-ANGLE1-AUDIO1.AC3.ff.mp2)
INFO: [mplex] MPEG AUDIO STREAM: c0
INFO: [mplex] Audio version : 1.0
INFO: [mplex] Layer : 2
INFO: [mplex] CRC checksums : no
INFO: [mplex] Bit rate : 28672 bytes/sec (224 kbit/sec)
INFO: [mplex] Frequency : 44100 Hz
INFO: [mplex] Mode : 0 stereo
INFO: [mplex] Mode extension : 0
INFO: [mplex] Copyright bit : 0 no copyright
INFO: [mplex] Original/Copy : 1 original
INFO: [mplex] Emphasis : 0 none
INFO: [mplex] Scanning for header info: Audio stream c1 (/Users/mrash/Desktop/COMICPARTY1/TITLE02-ANGLE1-AUDIO2.AC3.ff.mp2)
INFO: [mplex] MPEG AUDIO STREAM: c1
INFO: [mplex] SYSTEMS/PROGRAM stream:
INFO: [mplex] rough-guess multiplexed stream data rate : 0466848
INFO: [mplex] target data-rate specified : 3000000
INFO: [mplex] Setting specified specified data rate: 3000000
INFO: [mplex] Run-in Sectors = 89 Video delay = 43745 Audio delay = 46748
INFO: [mplex] New sequence commences...
INFO: [mplex] Video e0: buf= 235520 frame=000000 sector=00000000
INFO: [mplex] Audio c0: buf= 4096 frame=000000 sector=00000000
INFO: [mplex] Audio c1: buf= 4096 frame=000000 sector=00000000
++ WARN: [mplex] Stream e0: data will arrive too late sent(SCR)=2101248 required(DTS)=2100800
++ WARN: [mplex] Video e0: buf= 210076 frame=000685 sector=00002241
++ WARN: [mplex] Audio c0: buf= 3975 frame=000874 sector=00000317...
The same happens when i only chose one audio track. What went wrong? I strictly followed the guide at major's homepage.
Use SVCD or XSVCD profile instead of generic MPEG2 profile, and email me the process output in those cases. My email is major4@mac.comOriginally Posted by Mr.Ash
Extract Audio and video from Multiplex karaoke DVD and re author
By quebecLA in forum Video ConversionReplies: 1Last Post: 8th Jul 2011, 23:01 -
Video with L/R tracks to DVD with 2 channel audio tracks
By Downloader in forum Authoring (DVD)Replies: 2Last Post: 22nd Aug 2010, 02:56 -
Hi all, I need program to batch de-multiplex mpg files with 2 audio tracks
By mmdmmd in forum AudioReplies: 4Last Post: 14th Oct 2008, 16:57 -
Multiplex SD Mpeg with ac3 audio
By hartless in forum DVB / IPTVReplies: 8Last Post: 9th Sep 2008, 07:59 -
Multiplex with two audio streams
By heretic754 in forum AudioReplies: 2Last Post: 2nd Jun 2007, 00:44
