  1. Member Sakuya's Avatar
    Dec 2002
    Hello. I have an AVI that uses this codec (data from GSpot):
    4CC: wmv3
    It says I have 2 compatible codecs installed and they are:
    Microsoft Windows Media Video 9
    WMVideo Decoder DMO
    The strange thing is, I don't remember downloading those things. The only codec I have installed is FFDSHOW. I remember the owner saying not to use FFDSHOW to decode the AVI but here, it works just fine for me. That's weird. Just wanted to know why.
    Aug 2004
    Tigard, OR
    did you run the WMP Codec Pack from windows update?
  3. Member Sakuya's Avatar
    Dec 2002
    I don't remember. At least not recently.
  4. Mod Neophyte redwudz's Avatar
    USA
    Those are probably the ones built into the operating system (OS). You will find quite a few from MS especially, even before you install any others.
    One that is not from MS is the MPEG2 codec. You have to install that yourself, apparently because of copyright issues. It's nice to know the MS is not all powerful in everything.
  5. Banned
    Aug 2004
    USA
    If its "AVI" then its not a WMV codec, probably the hacked DivX 3.11 alpha
    The WMV codec range is only used in WMV formats or ASF, AVI's are probably 3.11 Alpha
    Signature removed.
    / Moderator Cobra
