I copied the VIDEO_TS folders from the DVD-RWs created by the JVC DR-M10.
If I now want that content to be on a DVD-R, do I have to re-author?
In other words, I want an identical copy of what was on the DVD-RW on a DVD-R. Is it just a simple thing as copying the VIDEO_TS folder to a DVD-R?
I no longer have the original DVD-RWs.
I think if you copy the contents of the ripped VIDEO_TS folder in to a DVD-Video burning application (like Nero) and burn a new DVD, it should work. Maybe try one on a -RW first to make sure.
yes that is all you need to do is create a new dvd-video in nero
and drag the files to the VIDEO_TS folder and burn it -
I use DVDDecripter to make BU of my DVD-RWs (until I get a chance to re-author the content). Works great.
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 11:10 -
About to author, what BG Music
By nirbhayn in forum Authoring (DVD)Replies: 4Last Post: 20th Aug 2009, 21:14 -
how to author a CD?
By michcio in forum Authoring (VCD/SVCD)Replies: 4Last Post: 2nd Sep 2008, 13:06 -
Does Tmpg Divx Author encode or it only author ?
By BlackShadow90 in forum Authoring (DVD)Replies: 3Last Post: 29th Jul 2008, 03:56 -
seems to author twice
By BroomQueen in forum Authoring (DVD)Replies: 7Last Post: 15th Oct 2007, 08:22
