I am converting a pal svcd to ntsc svcd. In the process, i open up the mpg2 file in vdub mpg2, and according to file information there is a audio skew of -80ms. I extracted the audio as wav, and converted pal to ntsc, in the process i also set a delay of -80ms in besweet. Will this correct the audio skew for when i mux with bbmpg, or is there a different method i should follow? thnx.
