Slimline clamshell cases are about 1/2 the thickness of standard cases. Is there any program that properly resize cover art to fit. I cut and pasted and reduced the spine to 1/2 width but the program I'm using to print keeps resizing for a standard box. A normal box insert is 10 3/4 inches but for slimline it needs to be 10 3/8"
This post may not be getting the attention it deserves here. Moved to the Media forum
I discovered that the program I'm using to edit the covers,Irfanview,has a very configurable print utility. It allows precise selection of the size of the print image. So I have answered my own question.
I used the regular ones and trimmed them down to fit. Then I got some of the regular cases in my next order....
You can use Photoshop or any graphics software. Make a template sized 10 1/2w x 7 1/4h, then insert your jpg image of the cover. Print on legal-seized paper and voila!
There's a good sale at CompUSA: you get both Photoshop Elements and Album for $50 after rebates.
Good luck.
DVD Storage Cases
By Tenacguy in forum MediaReplies: 6Last Post: 10th May 2010, 18:43 -
HP Slimline computers for video editing VS full size desktop?
By vid83 in forum ComputerReplies: 3Last Post: 9th Feb 2009, 17:26 -
DVD/CD Jewel Cases
By wulf109 in forum Off topicReplies: 3Last Post: 23rd Jul 2008, 17:13 -
SLIMLINE dvd case printing
By efiste2 in forum Authoring (DVD)Replies: 12Last Post: 8th Oct 2007, 15:27 -
Double DVD Cases
By royal007 in forum MediaReplies: 0Last Post: 16th Aug 2007, 18:45
