Hi,
I am trying to create a menu with TMPGEnc DVD author. I got a clip of the original menu with four box containing the chapters to select. It is the beginning of the video file before the movie starts. I seen that these clips runs in a loop until the chapters ( any of the 4 scene boxes is selected ) or the 'play entire movie' is pressed. How can I create a menu like the professional with TMPGEnc DVD author or with another suggested tool. Is there a guide?
Thanks,
rage
The menu creation aspect of Author is pretty simple. You can switch only some much around and customize it only within limits. You might be able to do what you want and it might be completely impossible to re-create it the way you want.
DVD-lab is far far more powerful and could most likely do what you need, but there is a decent learning curve to overcome. There are some guides that you can use google to find if you decide to continue. Good luck.
menu problem in TMPGEnc DVD Author 3
By sanduul in forum Authoring (DVD)Replies: 13Last Post: 23rd Oct 2007, 19:20 -
TMPGEnc DVD Author 1.6 thumbnail menu issue
By Bix in forum Authoring (DVD)Replies: 0Last Post: 3rd Oct 2007, 10:00 -
TMPGEnc DVD Author 3 (MENU PROBLEM)
By jaffacaique in forum Authoring (DVD)Replies: 9Last Post: 18th Sep 2007, 19:43 -
TmpgEnc DVD Author 3 - Question About Menu Music
By heyjjjaded in forum Authoring (DVD)Replies: 10Last Post: 30th Jul 2007, 13:16 -
Menu troubleshoot using Tmpgenc Dvd Author
By tekka06 in forum Authoring (DVD)Replies: 8Last Post: 4th Jul 2007, 03:53
