I tend to record mpeg2 using a Compro or Dvico hardware encoder set to 6 or 7 mbps. I then author with Tmpge Author and shrink to fit with DVD Shrink or Intervideo DVD Copy. I wanted to improve on the output, so I have lately used Tmpgenc to re-encoding the mpeg2 stream on 2 pass vbr, then I author with Tmpge Author. The result is smoother, but I now have an interlaced output from a deinterlaced original. I get this even when I select non-interlaced in the Tmpgenc options.
1) How do I rid myself of the lines?
2) Is there a better encoder that avoids this?
Results 1 to 1 of 1
How do you avoid motion lines in your ripped DVD file?
By metrosuperstar in forum DVD RippingReplies: 39Last Post: 18th Sep 2010, 17:04 -
vdub "blend" deinterlace works, but now lines are jagged
By italo4ever in forum Video ConversionReplies: 3Last Post: 29th Jun 2009, 23:35 -
How to avoid Generation Loss as much as possible?
By Undead Sega in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 12Last Post: 16th Sep 2008, 19:51 -
What is PVOP and how do I avoid it?
By Strumpah in forum EditingReplies: 4Last Post: 12th May 2008, 20:04 -
How do you avoid banding?
By zanos in forum MediaReplies: 3Last Post: 13th Mar 2008, 23:57
