I want to convert an avi file (made by pinnacle dc10+ codec) to divx. The source file is 768x576 pal, I chose the 2:1 reduction (high quality) filter, low-motion, crispness 75%, bitrate 910, audio is mpeg layer 3 32bit 22khz mono. About 1/4 of the conversion, an error message appeared "Video Source AVI[ICDecompress] error: aborted by user (-10)". Does anyone knows what happened?
ShiZZZoN-
might be a bad frame
Scan thru the clip where it fails at and play it right before it occurs for 1 minute(bout 30 sec before it occurs thru 30 sec after)
if video freezes at ALL, you got a bad frame
Hi Sean,
Thanks for your help. I've checked as you said, and I think there's really a bad frame over there. So what can I do with it? -
well at dvd digest or http://www.digital-digest.com/dvd/
if you scrool to the bottom you should see a tools section there they have some tools that you can fix bad frames because i have seen some tools there that you can do that
well hope this helps bye
DVD FLICK, Start-up Error Msg-Unable to created txt file. Last DLL error: 5
By jacknscoob in forum Authoring (DVD)Replies: 5Last Post: 4th Mar 2012, 08:58 -
any media player can play an unpoined part of an avi file without error msg
By perfection in forum Newbie / General discussionsReplies: 2Last Post: 29th May 2008, 01:58 -
Question about Windows error msg and high cpu when right clicking on avi
By jimdagys in forum ComputerReplies: 3Last Post: 4th May 2008, 17:01 -
error msg when try to record on drw-500
By harryb in forum Newbie / General discussionsReplies: 2Last Post: 9th Nov 2007, 23:57 -
TMPGenc just closes - no error msg - no rhyme or reason! Help please.
By brightsun23 in forum Video ConversionReplies: 3Last Post: 15th Jun 2007, 11:42
