Upon insertion of a disc the player searches and after 5-7 seconds it says "No Disc" and on TV it shows "This type of disc cannot be played.".
I thought it was the laser-unit which has gone bad or worn out or something, but I only have this problem with (all my) DVD discs and not with any Audio CD.
(I know the laser operates at another frequency for DVD and CD, but it's the
same laser right?)
Any tips or suggestions on what you think it might be are welcome ofcourse
Cheers,
MrSnake
Sony DRU-500A v1.0d
Toshiba SD-M1302 v1006
Philips DVDR885P v1.7/8 -
If the same disc played before on that unit and doesn't play now, you may just have a problem with dust/smog accumulation on the laser objective lens.
Open up the player and use a cotton swab (Q-tip, etc.) and either denatured alcohol or some type of cleaner like "Windex" and spray a small amount on the swab (not on the laser!). Then rub the lens very gently on the top surface, then use the other end of the swab to dry the lens and finish the job.
Try playing the same disc again and see what happens. This is not a foolproof repair, you may have something else wrong, but it's a good place to start.Ethernet (n): something used to catch the etherbunny -
Thanks for the reply, but I already tried a lens cleaner disc and even cleaned it manually myself, without luck :/
Sony DRU-500A v1.0d
ImgBurn "options" problem/directly cloning DL DVD to a blank disc
By gastrof in forum Newbie / General discussionsReplies: 4Last Post: 25th Apr 2012, 20:40 -
Editorial: Why "HD DVD" Is Thumping "Blu-ray Disc"
By Specialist in forum Latest Video NewsReplies: 146Last Post: 16th Feb 2008, 08:08 -
"Data Disc DVD" Audio Problem
By U87 in forum DVD & Blu-ray PlayersReplies: 5Last Post: 17th Jan 2008, 10:24 -
Daewoo DVD P480 "no disc" problem
By zodiax in forum DVD & Blu-ray PlayersReplies: 2Last Post: 2nd Jan 2008, 07:28 -
Sony RDR-HX525 DVD recorder- Problem with disc "Zapping"
By shytalker in forum Newbie / General discussionsReplies: 0Last Post: 30th Jun 2007, 04:56
