please help...
i got a mkv file, when i play it i can view the subtitles
but when i throw it in tempgnc and convert it to mpg the subtitles disappear...
what am i doing wrong...
Let me guess.....
Your using Media Player Classic to view the MKV file.
Media Player Classic has a built in subtitle filter that only functions in Media Player Classic.
To view subtitles in Windows Media Player, or TMPGEnc (DirectShow), you'll need a DShow filter like VOBSub.
It also helps to extract the sub from the MKV file and give it the same base name as your MKV file before you load it into TMPGEnc. (Just load the MKV file the same as before but have the sub in the same directory) -
Yo, check this post so see if you could make it through. There are 2 of them (mine is the second (NightScream) so try them out).
https://www.videohelp.com/forum/viewtopic.php?p=1018674#1018674
problems converting mkv to avchd
By mattybut in forum Video ConversionReplies: 3Last Post: 22nd May 2011, 01:54 -
converting mkv to avi + problems
By sgbd in forum Video ConversionReplies: 8Last Post: 28th Dec 2010, 14:53 -
Having problems converting from MKV to Mp4
By brucexx in forum Video ConversionReplies: 2Last Post: 10th Jun 2010, 19:52 -
Problems with converting MKV to AVI
By Sayuri in forum Video ConversionReplies: 25Last Post: 1st May 2010, 08:57 -
Converting MKV to a smaller MKV file
By Boriskali in forum Video ConversionReplies: 3Last Post: 1st Dec 2007, 07:07
