  1. Im capturing video from my ATI All in Wonder card, and its set to DVD, I normally use Ulead movie factory 3 to author & burn which normally works great. I put the DVD into my component JVC XV-NA77, and video is fine, but I have no sound. If I speed up the play to 1.5, then sound is perfect. Some how these must be out of sync? It doesn't matter if I capture from ATI AiW card at low, medium or best DVD quality...I get the same sound problem. Right now as I type this, I'm try the same mpeg file using Nero Vision, but it takes for ever to author compared to Ulead MF3.
  2. Member sacajaweeda's Avatar
    Sep 2003
    Would I lie?
    Is your sample rate 48k?
    "There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke
  3. Video: mpeg2, 24 bits 240x352, 29.970 fps.
    Audio: mpeg layer 2 files,
    Attributes: 4800 Hz, 16 bit stero
    Layer: 2
    Bitrate: 224 kbps
  4. I twould be nice if someone could solve this problem. I don't see why it was moved. it is a newb question and I followd the rules for former forum.
