What is overburning? When my drive says it doesn't support overburning, what do they mean?
If you look to the left you can click on a link called "Glossary". If you click on that link you can scroll down and click on the word "overburn". That will give you a definition of overburning.
If your drive says it doesn't support overburning, that means you can't overburn with that drive.
DVD overburning. Is it possible?
By eroy in forum DVD & Blu-ray WritersReplies: 53Last Post: 6th Sep 2010, 17:57
