hey i havent been downloading in ages and jut formatted my comp so i have no codecs installed...
what do people suggest as a good foundation of codecs to start off with on your computer so that most vids and movies will play?
Use gspot to check your files and ONLY install the ones you need.
Codec packs are more trouble than they are worth. -
yes that is what i have heard from others too... but what are the main few that will be needed...?
Xvid, (maybe Divx too), MPEG 2, DV if you have a digital camcorder. probably AC3 for audio.
CODECs
By channelk in forum Capturing and VCRReplies: 5Last Post: 3rd Feb 2011, 21:34 -
what codecs do I need?
By johnsees in forum Newbie / General discussionsReplies: 19Last Post: 23rd Jul 2010, 08:53 -
Help D; Codec Sniper Entries/Registering Codecs/Broken Codecs
By Antischism in forum ComputerReplies: 0Last Post: 5th Nov 2008, 14:29 -
Please explain codecs to me: codecs within codecs?
By idsane in forum AudioReplies: 5Last Post: 2nd Sep 2008, 14:39 -
Vista Codecs - New PC Requirements - Are Codecs Needed
By doggyofone in forum Newbie / General discussionsReplies: 6Last Post: 30th Aug 2007, 19:52
