I searched past postings and thought that this had been handled before, however, I am still at a loss.
I am currently using Version 1.5.19.59 of TMPGEnc DVD author. I use this software to author dvds created on my Panasonic HS2 dvd recorder. I record and edit the program on the Panasoniic HS2's hard drive. I then transfer the program onto a dvd ram disc. I use the high speed transfer function as not to re-encode.
The Panasonic HS2 is set to variable bit rate. I read a past post wherein the poster recommended constant bit tate. In that situation, TMPGEnc DvD was not accepting his .vro files.
I am confused becuase I have transfered over 50 discs in this manner with no synchronization problems. While if the way to go is constanct bitrate to ensure that there is no sync error, I would still like to transfer about 15 shows already residing on the Panasonic HS2's HD recorded with a varialbe bitrate.
The last 10 discs I authored are all out of synch three quarters into the propgram. I did use TMPGenc DVD to edit out a few errant commercial traces that the Panasonic let slip by--could use of the TMPGenc Dvd edit function introduce a synchronization error?
I have posts where in some people use DVDlab, is there a synchronization issue with this software? Are these the only two authoring software that coordinate with Panasonic created .vro files? I know that Panasonc has the Movie Album software but that does not do menus and the resulting mpg stream lconverts the ac3 to mp2 audio.
Thank you for your help and assistance
John
