I have family videos I have transferring to my hard disk. All of it is DV (AVI) format. Some of the source was Hi8 video (dropped into my D8 machine and converted to DV). A little bit was 8mm also dropped into my D8 for conversion and the rest true D8. I plan on batching these AVIs through TMPGEnc and want to use a good all round video bitrate for writing to DVDs. What do you recommend for video bitrate? Is 2 pass VBR worth the wait?. Also, what motion estimation is good for this material?Given this is not Hollywood quality
John
I use Vegas and the mainconcept encoder, but the basics are similar. My personal choice high 8000, low 4200, average 6000 2-pass vbr. Of course mainconcept is significantly faster than tmpgenc, so 2-pass is not the same imposition. I also use Vegas to produce at least a 2 channel (and sometime 5.1) AC-3 audio.
If you don't have a lot of movement (pans, zooms, action in frame) then CBR at 8000 will give you 70 - 90 minutes of high quality.
As I said, this is all personal. You should select a couple of scenes from each set of source material and do a couple of test encodes. You only need a couple of minutes of footage, so encoding will be quick. Burn the results to an DVD/RW and see what makes you happy. After all, you are the one who has to live with the results.Read my blog here.
Hey thanks GS. Your suggestions are in line with what I am testing. I am writing an RW right now so I should be able to see how it turned out. I am sticking with 2 channel MPEG audio as the source is nothing special. In fact I think the camera records 32KHz natively.
John
Advice on a camcorder for my needs ? ( hand held 3ccd or equivelent . .)
By stacks in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 10Last Post: 29th Jul 2009, 12:34 -
Raise Hand if your dvd burner is 5 years or older
By jsmithepa in forum DVD & Blu-ray WritersReplies: 37Last Post: 6th May 2009, 19:09 -
mpg file went burnt to dvd plays only in top left hand corner of tv
By johnkane1 in forum Video ConversionReplies: 0Last Post: 9th Feb 2009, 10:16 -
Need held from someone smarter than Pinnacle Tech Support
By frapnitz in forum Newbie / General discussionsReplies: 15Last Post: 9th Aug 2008, 02:00 -
Trouble With DVD Author. Please give me a hand.
By hellfire45 in forum Video ConversionReplies: 1Last Post: 19th Nov 2007, 01:31
