  1. I want to delete frames of a mpeg-2 file using TMPGEnc Plus without having to re-encode. Does anyone know how to do that?
    I captured a VHS using Sonic MyDVD with Adaptec card. The card is recognized only by MyDVD. Not recognized by Ulead Video Studio, Premiere, VirtualDub, or MS MOvie Maker.
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    I don't think (but I could be wrong...) that you can do MPEG editing with TMPGEnc Plus without re-encoding....
    There are a couple of Womble products that I believe can do this though.
    try this:
    http://www.google.com/search?sourceid=navclient&ie=UTF-8&q=MPEG%2D2+EDITOR
    If in doubt, Google it.
  3. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    If you use the mpeg tools> merge and cut, you can edit an mpeg without re-encoding. It's not a very good editer though, having used womble I'd recommend that too.
  4. The merge/cut feature in tmpgenc will not work (I think) because I need to cut the existing file and then joined the parts I want. The problem is what to do with the cut parts. I need to save the parts I want and then my problem comes. How to save these parts without re-encoding. When using the merge button, it ask for files I want to join.
    I downloaded Womble and tried for a while. I couln't find how to edit the file without re-endoding but at least it is faster (way faster!) then tmpgenc. Gotta read the help section and see if it's worth to buy it.
