I have loads of mpg files that have been playing fine. They are now causing WMP9 to stop responding, saying error downloading codec when played, .avi are fine. The only thing that has been installed is TMPGEnc 3 Express. I've tried installing a few codecs, but this has not helped.
Any ideas,
Mark
I would try another player. Zoom Player or VLC Media Player will surely work better than WMP9. (IMO almost anything would)
Try AVIcodec. It should tell you what codecs you have and what you need. -
Cheers, I'll give it a try. One thing I have noticed, the .mpg files were converted from avi, which are ok, maybe that has something to do with it.
On another note, how many codecs do I need installed, I cuurrently have the following. Just wondering if I have a little overkill
AC3 Filter
DivX Pro
XviD
AC-3 ACM decompressor
AVI codec
Cheers -
Ok, I reinstalled PowerDVD, which made no difference. when I lauch the .mpg, wmp starts to play and i noticed the message 'error downloading codec', it and then locks up after playing the film after a few seconds and you can't forward the film.
I installed zoomplayer, which doesn't lockup, you can forward the movie, but the video seems to pause inetrmittently, but the audio continues. You can then forward the movie and it will continue, with the same pause in video..
Mark
My Unlocked Phillips dvp3980 has suddenly stopped playing AVI files?
By UmmAddan in forum Newbie / General discussionsReplies: 5Last Post: 10th Mar 2012, 12:58 -
MKV files suddenly not playing properly on VLC
By thekenoshakid in forum Newbie / General discussionsReplies: 5Last Post: 6th Dec 2011, 00:24 -
.mpg file suddenly missing first 30 seconds.
By John97 in forum Newbie / General discussionsReplies: 1Last Post: 18th Nov 2010, 16:17 -
Suddenly no sound playing back audio (MP3) on MySpace
By phaedrus in forum AudioReplies: 2Last Post: 26th Jun 2009, 20:13 -
suddenly can't play mpeg files!!!!
By BillW in forum Newbie / General discussionsReplies: 3Last Post: 14th Jul 2007, 20:45
