i have a movie in avi format and i used tmpegnc to make it into a mpeg-2 and then i burned it to a dvd. when i went to watch it everything came out perfect execpt i had no sound at all. can somebody give me step by step details on how i can fix this problem...........many thanks.
First put the AVI into AVIcodec and see what kind of sound you have. If it is MP3 VBR you should extract the audio to WAV with a program like Virtualdub and use that with TMPGenc.
Open it in VDub anyways and see if it will let you extract the audio & save to WAV.
"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke -
This is the way I do it. After converting your avi to mpeg2, open the same avi in virtualdub and extract the audio to wav. From here you can either open both files in tmpgenc and author the dvd, or use ffmpeg to convert the wav to an ac3. Both wav and ac3 are supported by dvd, but I think ac3 use more compression. Good luck!
Question about AC3 Filter with MPC to increase sound when playing avi
By jimdagys in forum AudioReplies: 3Last Post: 13th Jan 2019, 16:50 -
problem with sound in .avi file
By mattwilsoni in forum Newbie / General discussionsReplies: 1Last Post: 26th Apr 2010, 11:06 -
Sound problem question
By mysts in forum ComputerReplies: 3Last Post: 20th Apr 2009, 14:13 -
Sound problem when converting AVI to DVD
By luvflt in forum Newbie / General discussionsReplies: 1Last Post: 9th Feb 2009, 17:12 -
AVI.net sound problem
By Den-2 in forum AudioReplies: 3Last Post: 18th Nov 2007, 11:36
