Ihave a quick question about containers. I am using mencoder (linux tool) to convert divx to mpeg2 files. Only problem is that mencoder cannot write mpeg2 containers. So the file ends up being a mpeg2 file in a mpeg1 container.
So I guess my question is what does this mean in the end? Would this cause any issues? It is still a mpeg2 file with the correct fps and resolution. Would this cause the dvd player to bug out and not be able to play the svcd? I was able to create the svcd with vcdimager and got a warning stating that this is a mpeg1 file. But it successfully creates the .bin/.cue file. Able to play the .bin file fine on the computer but haven't burned it and tested it out on a dvd player yet.
Just curious as to what would having a mpeg2 file in a mpeg1 container cause?
thanks
As to why I am using mencoder? It already comes with mplayer and I know how to use it and it is very fast. Would prefer just to use it instead of learning to use a new tool. -thanks again
Results 1 to 1 of 1
Blu Ray ripping container & codec question.
By jamesj84 in forum Blu-ray RippingReplies: 10Last Post: 15th Dec 2011, 12:18 -
H264+AC3 (MKV container) to H264+MP3 (MKV container)
By diebri in forum Video ConversionReplies: 3Last Post: 19th Oct 2011, 06:19 -
PNG Codec / MOV container question regarding a setting
By low-fat-al in forum Video ConversionReplies: 3Last Post: 12th Oct 2011, 20:12 -
change an MKV container to AVI container???
By Spdngblt56 in forum Newbie / General discussionsReplies: 10Last Post: 17th May 2010, 21:23 -
How do you move files from .ogm container to .mkv container?
By VidHunter in forum MacReplies: 0Last Post: 8th Mar 2008, 18:19
