Is there a good program that convert from avi to rm without losing too much quality?
Why do you want to convert to rm?
It is a proprietary format.
If you insist, then use rm converter 1.40 -
If you convert from avi to rm, does the file size lower? Like from 160mb to 40mb?
Try it and find out.
I have the program, but I usually convert from rm to avi or mpeg. -
RealProducer, straight from the horse's mouth. They did create the format after all, wouldn't make sense to not provide something for people to create content for it with.
There is a basic version for free.
File size depends on how much you compress it. If a smaller file size is your goal, this is not your solution.
Your solution would be to just recompress the AVI file into a smaller AVI file.
Dazzle dvc100 w studio 12 does it capture AVI 1 or AVI 2 or DV-AVI
By st711 in forum Capturing and VCRReplies: 1Last Post: 10th Dec 2009, 17:30 -
avs (avi to avi) ends up out of sync ... winavi output file too big
By mandy in forum Video ConversionReplies: 1Last Post: 21st Aug 2009, 05:56 -
ffmpeg choppy audio from large avi but not small avi source file
By cybertheque in forum Capturing and VCRReplies: 9Last Post: 13th Oct 2008, 15:38 -
ffmegX v0.09w and converting avi videos into avi.ff.avi videos
By paddymick in forum ffmpegX general discussionReplies: 2Last Post: 2nd Nov 2007, 23:10 -
How To Split Single DV AVI file into Multiple DV AVI files using Time Stamp
By insysnet in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 23rd Aug 2007, 12:49
