Hi,
I know my topic is a little bit off topic but I have nowhere to go.
I installed an internal DVD drive on an external usb enclouser. Everything seems work perfectly except that the drive can only read CDs but not DVD movies. Please give me some hints on this, it has haunted me for one month.
thanks in advance.
Results 1 to 12 of 12
Are you using usb1.1?If you are then its not fast enough.Get a usb 2.0 card.
Is the enclosure meant for usb 2.0?Might have 1.1 cable.
The only thing i can think of is that somethings wrong with your usb transfer rate or the dvd device is knackered or your system isnt powerful enough to play dvd movies,hard to tell unless you give the specs on your system.
I have a USB 2.0 drive and it acts like a regular drive. Reads and writeds CDs/DVDs.
My lap is IBM T40 237358U,
1.3GHz PentinumM, 768 MB, 2 USB 2.0 ports. what else do you need?
I also have a 8x dvd internal drive on my lap. However, it cannot read
dvd-r or +r that I burned with nero express (with or without finalize does not change the situation). I can read the dvdr in other computers (xp machine). Anybody know this too?
ps. I never expected to receive so many responses, thanks for every input. -
I made a big mistake. It's actually a 1394 connection.
The enclouser has both usb 2 and firewire connections. When a dvd movie inserted into the drive, in 'my computer' , it shows the title of the movie and I can enter into the folder to look for the content, however, I cannot play it. Win Media player told me it's copyright protected, but I checked the region setup , it is region 1 (for gladiator). I also tried the methods of region free in the site, none worked. I then tried some region 6 movies (chinese movies), it can play the movies without any problem, But my dvdrom is purchased in usa, before I took it out from my desktop, it can play region 1 movies. wired problem.
DVD player with external Hard drive
By dbnite-wp in forum DVD & Blu-ray PlayersReplies: 14Last Post: 23rd Sep 2009, 02:46 -
External DVD Drive Won't Play DVD!
By sculptedstylus in forum DVD & Blu-ray WritersReplies: 1Last Post: 19th Feb 2009, 22:05 -
External Hard Drive to DVD Player through TV
By illpeeonu in forum DVD & Blu-ray PlayersReplies: 7Last Post: 5th Feb 2009, 13:02 -
external DVD drive
By uglijimus in forum DVD & Blu-ray WritersReplies: 2Last Post: 13th Jun 2007, 07:47
