how big can my video file be so it will fit on a miniDVD?
i saw the miniDVD option in nero but i cant find any info about it
700mb (or 650mb if you're using the smaller capacity CD-R)
If God had intended us not to masturbate he would've made our arms shorter.
George Carlin -
are 100% sure because with vcd/svcd you can burn video files that are greater then the cd's 650/700mb
I dont think minidvd is burned in mode2 like svcd & vcd, suppose you could manually change software to burn in mode2, not sure how this would affect playback compatibility
If your looking for the sizes of the small DVDs, the 8cm ones, then your sizes are as follows:
DVD-1 (8 cm, SS/SL) 1.36 gig (1.46 BB), about half an hour
DVD-2 (8 cm, SS/DL) 2.47 gig (2.66 BB), about 1.3 hours
DVD-3 (8 cm, DS/SL) 2.72 gig (2.92 BB), about 1.4 hours
DVD-4 (8 cm, DS/DL) 4.95 gig (5.32 BB), about 2.5 hours
For a full listing,
http://dvddemystified.com/dvdfaq.html#3.3Have a good one,
neomaine
NEW! VideoHelp.com F@H team 166011!
http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
Folding@Home FAQ and download: http://folding.stanford.edu/
possible bad frame prob with file from Panasonic miniDVD camera
By ronhud in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 4th Apr 2012, 17:40 -
Problem burning .avi file to dvd.. Burner tells me file is too big when not
By accesskb in forum Newbie / General discussionsReplies: 17Last Post: 6th Mar 2012, 19:28 -
video file to big?
By just in forum Newbie / General discussionsReplies: 4Last Post: 21st Nov 2008, 00:34 -
395MB folder to big to fit on 700MB CD in ImgBurn
By happydog500 in forum AudioReplies: 30Last Post: 30th Jul 2008, 13:58 -
Video Question (file smaller to fit a double layer)
By MKoivuFan in forum Newbie / General discussionsReplies: 7Last Post: 15th Mar 2008, 13:38
