My source avi file is fine but once i've converted I get a couple of bad frames EVERYtime in the same place.
I only need to mask 2 seconds, Virtual Dub only allows me ot save the file back to AVI. The trouble is I have my VOB written and everything.
Is there any possiblity of masking those 2 seconds and save the MPEG2?
thanks in advance
Galvin
By "mask" do you mean delete ??
If so try Womble mpeg VCR or Mpeg2schnitt.
Cheers,
Moonstomp.Just because you're nobody, doesn't mean that you're no good. Just because there's a reason, doesn't mean it's understood. It doesn't make it all right ! (The Specials) -
whoops...it's actually a VOB file that I need to edit
Same thing:
1. Remane your .VOB to .mpg
2. Load into MPEG2Schnitt
3. Cut out the Bad frames.
4. Save as new .mpg
5. Rename as .VOBJust because you're nobody, doesn't mean that you're no good. Just because there's a reason, doesn't mean it's understood. It doesn't make it all right ! (The Specials) -
MPEG2Schnitt isnt loading the full file. Its only loading 30 seconds of the clip
any suggestions?
Premiere CS3 exporting bad frames
By spicediver10191 in forum EditingReplies: 4Last Post: 17th Apr 2012, 17:39 -
fixing bad frames
By vidclip in forum Newbie / General discussionsReplies: 2Last Post: 10th Jan 2010, 15:00 -
.avi file cannot be repaired - need to remove bad/corrupt frames
By realtechtalk in forum Video ConversionReplies: 0Last Post: 7th Sep 2008, 12:27 -
Cutting bad frames with VirtualDubMod
By lazaruz in forum EditingReplies: 2Last Post: 18th Sep 2007, 03:39 -
SVCD / MPEG2 - bad packet stops file.
By Steve Walsh in forum Authoring (VCD/SVCD)Replies: 5Last Post: 9th Jul 2007, 12:03
