i'm using ulead videostudio8 and having problems with capturing and trimming videos.
With the trimming of videos it goes through the render process fine of the clip i want to keep, but when i play it back there is only a amx of 3 secs of video there...anyone know why this is?
Also my capture card is Adaptec2010 and is capturing fine using the MyDVD software (software hasnt enough options). I want to use videostudio to capture as well and although it knows what my capture card is, its saying theres a problem with my capture driver ( using the latest driver).
If anyone knows the reasons behind these two problems i'm getting with videostudio8 i'd really like the help so i can get the editing done i need the way i'd like it......thanks all
Originally Posted by sylvester243
I've been using VS for years and I too at one time had trouble with the capture drivers. I think the drivers that it ended up using came from the firewire card install disk. I've only used an ATI AIW card or firewire for my captures so I don't know what to tell you about your Adaptec card.Yesterday I downloaded the world,
But it took up too much space so I had to purge it. -
i'm using a NTFS file system, i tried all the different capture plug-ins and render plug-ins, i'm only getting 3 secs in total then playback stops, basicly its rendering 3 secs and thats its.....stupid i know.....videostudio7 under fat32 never gave this hassles geez lol
VS 8's editor SUCKS Big Time! It is user hostle. Cuts are nowhere near exact-in fact you get more than you want. Use Cuttermaran-no re-rendering. It is quick and easy to use. Also, TmpGenc is coming out with an editor that should be good. I just use VS 8 to assemble the edited cut clips and add effects, titles, sound, whatever. Then I can burn with VS 8.0, which does a good job, or save to a file.
You'd think if you were going to brag about some new feature you'd sure make sure it works!
I guess you've tried starting a new project and re-adding the clips. I vaguely remember something happening like this before and I think I repositioned the clips on the time-line and it worked or something like that. Not much help...sorrryYesterday I downloaded the world,
AviSynth Overlay and Trim Help
By NMeade in forum Newbie / General discussionsReplies: 20Last Post: 1st Apr 2012, 07:53 -
About TRIM and Subtitle
By DruidCtba in forum SubtitleReplies: 1Last Post: 3rd Feb 2011, 10:52 -
AVI Trim
By drgt in forum Newbie / General discussionsReplies: 6Last Post: 13th Nov 2010, 04:36 -
Batch trim a .MOV?
By romfre in forum Newbie / General discussionsReplies: 2Last Post: 20th May 2010, 06:21 -
How to trim wmv-hd?
By daz2712 in forum Blu-ray RippingReplies: 2Last Post: 26th Aug 2009, 09:55
