While installing PowerDVD SE I've received a prompt telling me that it has already detected a DVD Codec installed and that I should uninstall it before continuing.
The only problem here is that I've tried different software DVD Players and various codecs and etc. and don't know HOW to locate "said" codec to uninstall. What are the magic extensions to look for? Are there specific dirs I should be looking for?
I've been encoding/ripping/editing/making all types of movies for years find myself now stumped. Thanks for your help!
User0101
Hello,
Not entirely sure but try gspot and see what codecs you have installed (I think virtualdub would also work). Look for mpeg2 or dvd codec or some variant like that. I believe in windows if you go to control panel look up video or something like that. There should be a way to remove it.
KevinDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
convert video with Photo JPEG codec and MS IMA APMCD audio codec
By devil_doll in forum Video ConversionReplies: 3Last Post: 21st Jan 2011, 15:10 -
Can Codec ID/Codec Hint make a difference on the video?
By dzsoul in forum Video ConversionReplies: 2Last Post: 1st Jun 2009, 20:40 -
HELP! Video that says its one codec that its not.?!?!
By doctor37 in forum Video ConversionReplies: 2Last Post: 17th Jan 2009, 14:34 -
Video Codec
By Dave1024 in forum Video Streaming DownloadingReplies: 1Last Post: 15th Apr 2008, 02:46 -
video codec
By ribac in forum Software PlayingReplies: 1Last Post: 8th Feb 2008, 02:09
