Anyone know a way to extract audio from a menu under OSX?
The menu is usually the small VOB that's at the beginning of the first title set on DVDs (VTS_01_0.VOB). If you rip that VOB, then demux it using something like Extractor (http://denisx.dyndns.org/extractor/) to demux it and get the ac3 audio file, and then use something like MAC3Dec to convert the ac3 to aiff, which you can then convert to whichever format you want.
I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté."
Main menu/chapters/audio etc all on one motion menu in Encore. Possible?
By Killer3737 in forum Authoring (Blu-ray)Replies: 10Last Post: 11th Feb 2012, 13:08 -
how to extract audio from avi
By ShrinkDWorld in forum AudioReplies: 2Last Post: 2nd Feb 2012, 17:58 -
HOW do I extract 1 audio track from a .ts / .m2ts with 4 audio tracks?!
By elgy in forum DVB / IPTVReplies: 25Last Post: 23rd Jan 2011, 23:28 -
extract dvd menu text & time
By msdiane in forum Newbie / General discussionsReplies: 0Last Post: 26th Oct 2008, 11:25 -
Is it possible to extract the video from a motion menu?
By mjvgiese in forum DVD RippingReplies: 2Last Post: 3rd Dec 2007, 21:31
