i dl a movie which had two parts. one of them was 146mb and the other 153mb both were in avi format. i used tmpgenc to convert the 153mb to a valid vcd format mpg 352*240,29.97fps,CBR 1150kbs, layer 2 44100Hz, 224Kbps. the ending result was a 595mb mpg file.. problem with this size is that now i cant put part one and two of the movie in one cd if i convert the other why is it so big. how can i get it to be smaller it took 5hr to convert part one alone...it would be stupid to have part one on cd 1 and two on cd 2 and a waste of cdrw
If your player support XVCD and you can live with bloody picture quality, reencode and lower the bitrate.
Use a bitrate calculator. http://www.vcdhelp.com/vcdtools.htm
what do i do to make a dvd movie small enough to fit in one disc?
By polka in forum Authoring (DVD)Replies: 3Last Post: 24th Mar 2012, 02:53 -
how to shrink a movie to fit a dvd 5?
By just in forum Newbie / General discussionsReplies: 2Last Post: 30th Oct 2008, 00:58 -
makin the movie fit
By xstatictravis in forum DVD RippingReplies: 12Last Post: 11th Apr 2008, 09:52 -
makin a movie fit?
By xstatictravis in forum Authoring (DVD)Replies: 1Last Post: 8th Apr 2008, 21:30 -
AVI to DVD - Movie doesn't fit on screen
By tmac2085 in forum Newbie / General discussionsReplies: 2Last Post: 25th Jan 2008, 11:18
