I am new to this so I hope someone will be able to help me clear my mind.
I got a Zenith 413 DVD player. It does not play VCDs. Is it possible to modify the firmware of this player so that it can play VCDs? Some of my DVDs freeze when I skip to the next chapter. Is this the DVD or player problem? My previous one (APEX) would play them fine.
If you have checked the 'DVD Players' to the left, apparently it won't play VCD according to the info there. You might do a 'Google' search for the player model and see if there are further comments. As you mentioned APEX will play almost anything.
You should check somewhere like www.nerd-out.com Someone there would probably know....
New LG DVD Player not playing VCDs
By atlmallu in forum DVD & Blu-ray PlayersReplies: 15Last Post: 4th Dec 2010, 15:28 -
No sound when playing playing burned DVD on stand alone player
By ibzomie in forum Newbie / General discussionsReplies: 2Last Post: 23rd Aug 2010, 13:11 -
DVD units playing VCDs in black and white only.
By electric green in forum Newbie / General discussionsReplies: 1Last Post: 26th Sep 2008, 12:37 -
I want to play VCDs on my laptop
By Michel-lyn in forum Software PlayingReplies: 2Last Post: 22nd Dec 2007, 10:38 -
Playing vcds on Liteon lvw 5001
By northy44 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 25th Sep 2007, 07:50
