A film i have obtained is a dvd replica and is a .img file the sample is .vob
I looked up some information on how to burn this and i tried the method using dvd decrytor but the dvd would not play just load then stop before it played on my pc and dvd player.
What programmes will i need and what method step by step to burn this .img thats 4.2 gig onto a dvd disk with my pioneer dvd writer 106d so i can view on my pc and my dvd player.
thanks in advance and be as quick as you can
Closed Thread
Results 1 to 20 of 20
The guides are located along the top left of the screen. That's far faster than waiting for someone to reply with the same information.
Please read the guides yourself and don't ask members for step-by-step instructions - even if you're in a hurry. That's all covered in the guides, and you'll just have to read them yourself. Good luck with your project
Well i tried using dvd decrytor and selected the file pressed w and burned it but when i try and play it it just doesnt load and crashed on my comp and on the dvd player it just sticks on load.
Please help i have read the guides but cant find the help i need, i have checked the .img topics already etc
Hehe the rush is the fact its now 2:21 and am desperate to see this film and my dads in bed SHOUTING at me to get the hell of lol coz a want to watch this film before bedtime as am pretty young lol.
If you could just point me in the right direction even, the prob is i extract the .img downloaded dvd decryptor open pressed w selected the .img burned and yet it doesnt play it just "LOADS" in dvd player and crashed on My Computer!
So please couldnt you help or really point me in exacly the same direction lol, if you have a parent shouting at you contstantly when your trying to do something it really does not help.
Also the fact that am refreshing this post every 30 seconds waiting for an answer lol
Since i am a very impatient person i tried extracting another .img from the rars and then using dvd decryptor again and this time it worked so i dont know why it didnt work the first time.
Thanks for the help i guess... (sorta)
anyways i dont know why it now works but it does so am not complaining and hopefully the time being screamed at was worth it!
I do not know who Richard Simmons is but Katie Holmes is most definitely a goddess !!!
Some people here are a bit prone to jumping to conclusions, don't worry about it.
Actually, it kind of sounds like a downloaded/pirated movie. I saw a report about piracy on TechTV, and it sounds similar to this. Here's what I remember:
Bootleggers often compress a DVD into an image file (in this case, an IMG file) and then compress the image into a set of RAR files. Also, the bootlegger groups often enclose a VOB file called a "sample." The sample contains a short clip from the movie/program to show what kind of quality the bootleg is. According to TechTV, similar methods are used for VCD bootlegs.
I hope that it isn't a bootleg that you are dealing with, because that is definitely frowned upon here. Giving the benefit of the doubt, check the burning tools section of this site. You should find something that will burn IMG files.Knowledge is Power, For Real!
they probably used some butchering tool to strip the crap out and failed miserably
that's what you get with these 'types' of DVD's, a no work/no money back guarantee
it would be a rather simple to fix if you done a few things but I don't wish to help as I have my doubts as to the legality of this DVD :P
p.s. you could always 'obtain' it again as maybe one of the RAR files is corrupt
ahhhhhhhh..... and I am spent .......Originally Posted by Supreme2k
If in doubt, Google it.
Replica is a DVD rip and supply group; it's a guaranteed pirate copy.
What you do is your business, but just to be safe, I suggest that you don't ask about those things here on the forum at least. Look in the guides and I'm pretty sure that you'll find your answers quickly.
And just to answer your question, the next time you get an .img file, give either DiscJuggler or Alcohol 120% a go...you should be fine from there.
File wont play from memory stick but will from disc
By muay in forum DVD & Blu-ray PlayersReplies: 7Last Post: 11th Jan 2011, 08:11 -
How to obtain a tiny sample of an *.img file from a huge *.img file
By lousk in forum Newbie / General discussionsReplies: 3Last Post: 16th Nov 2010, 09:03 -
Img Burn software Where does the DVDIMAGE.MDS file go??
By orfajackson in forum Newbie / General discussionsReplies: 0Last Post: 26th Jul 2009, 14:46 -
IMG Burn says - File too large!
By orfajackson in forum Newbie / General discussionsReplies: 6Last Post: 26th Jul 2009, 14:41 -
wmv file wont play nor convert
By excitezone in forum Newbie / General discussionsReplies: 7Last Post: 18th Dec 2007, 13:56
