i'm not sure what the heck i'm doing wrong but the world of the vcd seems not to want me in it. I exported my fcp project as an uncompressed quicktime dv stream. i then dropped it in to toast and chose vcd. it incoded and i burned it. what the heck neither my mac or my jvc dvd player(it is listed as a player that plays vcd & svcd). I must be doing something wrong, but my dvd player doesn't even recognize that there is disc in it...
help me please!!
brett
Ok, your DVD player probably doesn't support CD-R's try using CD-RW's.
And what is the problem on the Mac?
What did you use to play it on your Mac?
I never tried to convert a DV file with Toast but as far as I know it should be possible, but you can always try it with a Quicktime export. Try the DV codec the quality won't be that bad.
Mark,
The Netherlands -
If your DVD player also plays audio CDs then burn an audio CD-R and verify your player laser system etc can read the disc.
Toast 5 came with a sample disc that includes MPEG-1 files that you can use to create a video CD with known good format. Then you can work the DV problem
How to make flashes play normally in VCD?
By blair in forum Video ConversionReplies: 5Last Post: 20th Oct 2009, 05:14 -
How do I make my Samsung R150 recorder region free? I have the code to make
By charpee in forum DVD & Blu-ray RecordersReplies: 2Last Post: 26th Jan 2008, 06:10 -
How to make a VCD/SVCD with CD Audio (CDDA)
By Baldrick in forum User guidesReplies: 74Last Post: 24th Dec 2007, 18:37 -
How to make an autorun VCD in English please!
By jimiir in forum Authoring (VCD/SVCD)Replies: 10Last Post: 8th Aug 2007, 22:56 -
Trying to make AVCD/VCD with audio data
By Vejita-sama in forum Authoring (VCD/SVCD)Replies: 2Last Post: 4th Aug 2007, 15:15
