I have been using tmpgenc author for a while and thought I would like to try something more complex. The problem I am running into is during the compile process of dvd-lab I get a critical error stop telling me that there is a problem with the movie and that I should reconvert it.
I use tmpeg to make the m2v and always rip the audio out of the movie to ac3. THis format works great for tmpgenc author but no success with dvd lab I am using the 1.4.1 beta 2 version.
Any hints would be greatly appreciated
My brain hurts......
thanx man appreciate the help beta is only good for 30 days so i guess ill try the 1.3.1 and wait for a stable fix
unless pro is finalized beta's = many many bugsMy brain hurts...... -
You should be able to upgrade to 1.4 beta 2(non pro) with your current code. That might give you some relief.
Also, the Pro betas have been coming once a month here for a while, so the expiration may not be an issue.
Just FYI.
Cyberhome AD-L 528 Crashes with DVD+R
By christaltips in forum DVD & Blu-ray PlayersReplies: 5Last Post: 29th Dec 2011, 07:54 -
DVD Player crashes when playing dvd with vietnamese subtitle
By ssalim in forum SubtitleReplies: 0Last Post: 28th Apr 2010, 16:52 -
DVD Decrytor crashes my editing program
By NickiMitch in forum Authoring (DVD)Replies: 7Last Post: 5th Aug 2009, 06:06 -
DVD Shrink 3.2 Crashes?
By LCE in forum Newbie / General discussionsReplies: 6Last Post: 4th Feb 2008, 03:18 -
TPMGEnc DVD Author 3.0.9.166 crashes on writing to disc
By gayclarke in forum Authoring (DVD)Replies: 4Last Post: 10th Oct 2007, 04:40
