If I right click on a gif,win xp will only allow me to svae it as a bitmap.How do I change this?
GuestGuest
mine does the same thing
I started to use mozilla when i need to save pictures -
bitmap should be a good, 24 bit representation of the file... once downloaded you can use PSP or other apps to convert to JPG, GIF or whatever flavor you desire.
Edit: Hmmm.. this work machine has W2K and if I right click BMP and JPG are given as an option -
Sometimes, deleting your temporary internet files clears up this problem, and allows you to save .gifs as .gifs again. If you're trying to save animated .gifs, saving as .bmps doesn't always give you the full effect.
Click on the Land O Lakes butter maiden's knees for further details.
In Internet Explorer, click on Tools | Internet Options..., then under Temporary Internet Files click on Delete Files....
Convert batches of SRT to SUB+IDX - smooth bitmaps
By rotven in forum SubtitleReplies: 5Last Post: 29th May 2015, 13:15 -
Saving/capture solutions for saving off (extending) DVR
By ET3D in forum Newbie / General discussionsReplies: 1Last Post: 28th Oct 2011, 18:13 -
Video to .gif converters? (animated gifs)
By Hank Kinsley in forum EditingReplies: 1Last Post: 30th Aug 2010, 23:13 -
Create Subtitle File from Bitmaps
By otternase in forum SubtitleReplies: 2Last Post: 30th Jul 2010, 12:26 -
Easy way to resize animated .gifs?
By Ai Haibara in forum ComputerReplies: 31Last Post: 9th Jan 2010, 23:30
