Hi am a newbie to this software and am trying to put multiple mpeg 2 files on a DVD.
My problem is with the menu screen. I link each title to the movie files that corespond with the movie. I then relink each movie back to the menu so that when it is done it goes back to the menu.
When i compile it before i burn and run it in power dvd the menu screen blinks for 1 second and defaults to movie 1 then when thats over it automatically runs movie 2.
I have gone into the pbc tab and selected inf in the seconds tab and 0 in the other tabs.
I have read a few how to on this site but they only deal with 1 movie file not 5.
Thanks for all replies in advance!!!!!
don't relink - dvd lab will automatically link the end of the movie back to the menu, that's the default setting.
- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
ok i unlinked them but i still have the same problem the menu screen blinks and it starts movie one. I cant even get the chance to select movie one or movie 2.
and both movies run simultaneously without stopping.
What next? -
Where is the FIRST PLAY object pointed?
Look on the CONNECTIONS window. Most likely it is pointing to the first movie. If so, reset the FIRST PLAY to the menu. -
first play is pointing to the menu 1,
menu 1 has 2 text lines, line one goes to movie 1 and line 2 goes to movie 2 and thats it.
It still flashes the menu for 1 second and defaults to playing movie one and then immediately showing movie 2 almost like the were linked but they are not
More dvd lab questions
By sterankin in forum Authoring (DVD)Replies: 12Last Post: 16th Aug 2010, 16:13 -
Help with DVD-lab PRO.
By angles in forum Authoring (DVD)Replies: 2Last Post: 3rd Jan 2010, 17:19 -
DVD Lab question
By sumeshkri in forum Authoring (DVD)Replies: 5Last Post: 13th Nov 2008, 21:32 -
DVD Lab 2 error
By XL3/\/7 in forum Authoring (DVD)Replies: 4Last Post: 3rd Jun 2007, 06:54 -
DVD Lab Help!
By ardiani in forum Newbie / General discussionsReplies: 14Last Post: 25th May 2007, 07:52
