Hi,
Is there any application that can be used to take out silence at the begining and at the end of audio files?
I mean something that you select a folder full of audio files and this is done as a macro to all files in that folder.
Any help in this will be higly appreciated.
Gramophone
Results 1 to 9 of 9
I saw your thread title and thought it was about small children
There are a variety of programs you could use.
Soundforge, Nero wave editor,goldwave and the list goes on. -
Do you mean the 2 sec gap so cd players can reognise when the new track starts? or does your mp3 have silence at start and end?
What I mean is that when one converts tracks to WAV, MP3 or whatever format, there is always a couple seconds of silence at the begining or at the end of the file. I need not a software to edit audio, but an utility that I can select a folder full of audio files and take away that silence from those files without having to make that manually one by one.
Hope to be understood...
Gramophone -
I doubt it.Originally Posted by GRAMOPHONEWant my help? Ask here! (not via PM!)
I do not think there is a file which will batch run on every file in a specific folder
Add silence to beginning of track
By CSULB71 in forum AudioReplies: 3Last Post: 10th May 2010, 17:04 -
Inserting silence batch style!
By Jo The Veteran in forum AudioReplies: 3Last Post: 11th Sep 2009, 14:58 -
Remove Silence from large WMV's
By djbryson in forum EditingReplies: 3Last Post: 4th Jul 2008, 09:53 -
Spliting Audio Based on silence
By loster in forum AudioReplies: 4Last Post: 30th Aug 2007, 09:27 -
NON-COPYRIGHTED silence?
By saturndude in forum Newbie / General discussionsReplies: 15Last Post: 29th Jul 2007, 18:55
