    Sep 2003
    SW France
    Trying out the above, but when I come to save a file after editing it, the 'save' box only shows 3 of the 7 options wirh regard to format.
    Mpeg-vcr Edit Decision List
    Mpeg Video Elementary Stream (Video only) (Shown as default)
    Mpeg-2 Program Stream SVCD
    The following are greyed out
    Mpeg-1 System Stream (Audio & Video multiplexed)
    Mpeg-1 System Stream Video CD
    Mpeg-2 Transport Stream
    Basically all I want to do is edit an mv2 file and save it to Mpeg-2 Program Stream
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    You can try tmpgenc. It has a 30 day trial for mpeg2 encoding.
    Kevin
    Sep 2003
    SW France
    Thanks yoda313. Will give it a try.
    Nov 2003
    Before you give up on Womble I would send them an e-mail. They seem to be one of the companies that actually have a live competent person answer.
    Sep 2003
    SW France
    Thanks trolltuning - I've now done so and received the following message:
    Hello,
    Please note that the MPEG multiplexer formats are
    closely related to and restricted to the underline video
    and audio elementary streams.
    Those greyed out formats is because the current data
    is an MPEG-2 video only stream; and there is no
    practical use to add additional packet data without audio.
    Try to open an MPEG file with sound and check this again.
    BR,
    --- Chang
    Looks as if my capture program didn't capture the audio. I'm still looking for a decent capture program.
  6. "Looks as if my capture program didn't capture the audio. I'm still looking for a decent capture program."
    Are you using an ATI AIW card/Creative Audigy card combination? I found that the ATI program resets the audio input to "Line-in 2/aux 2", and it has to be re-set before starting capture. I use the "What u hear" option.
