Hello,
I'm having huuuuge (!) problems getting a whole heap of my SVCD colection transferred to DVD. The main problem is that most of them have 2 audio tracks (me being a big fan of commentaries)
I made all my SVCD's with DVD2SVCD. The are all PAL.
I'd like to be able to use SVCD2DVDMPG and then DVD Movie Factory to transfer 4-5 per DVD-R but I can't find a way to do it, as I'm pretty sure DVD Movie Factory only takes one audio track anyway.
Is IFO Edit the way to go for two tracks ?
I'd love to use Adobe Encore (my fave) but it doesn't support PAL SVCD resolution. (i.e. you can't "fool" it)
Anyways, my BIG problem seems to be in the de-mux/audio conversion stage.
Here's what I've done : Ripped the Mpeg file form the SVCD disc to my hard drive with ISO Buster.
Then I've tried TMPGEnc but it won't let me De-mux the original file. Well, it lets the audio into the program but says that the video is an illegal mpeg stream.
I've tried various Demuxing's (DVD-Lab, SVCD2MPG Etc) but haven't yet worked out how to separate the file into 3 (not 2 remember) and then be able to drop into a program like IfoEdit so I can keep my second audio track.
I'll stop now as this is getting a little wordy. I'm sure someone may be able to help me from the info above.
Thanks in advance !
- Mike
V2 will support this.
Audio track shorter than video track in MPEG Video Wizard DVD?
By xxxyyy in forum EditingReplies: 3Last Post: 30th Jan 2011, 14:24 -
Get audio track from DVD Extra instead of film sound track in VIDEO TS
By Josephine in forum Newbie / General discussionsReplies: 4Last Post: 2nd Aug 2010, 13:25 -
How to select audio track opening multi-track container in avisynth?
By lovyagin in forum Video ConversionReplies: 7Last Post: 23rd Sep 2009, 13:16 -
need to substitute spanish audio track with english track
By rebeltaz in forum AudioReplies: 5Last Post: 26th Dec 2007, 20:12 -
re-encode only video track of Quicktimes but keep audio track untouched
By brennbaer in forum Newbie / General discussionsReplies: 6Last Post: 29th Jul 2007, 09:25
