I have a PII 400 mhz computer with win98se 128mhz ram...
PROBBLEM>>>12 Gig HD.
I read on a few firewire card boxes in the store today that capturing requires 4Gig per 20 min of finished video... so I decided not to buy a firewire card just yet.
I noticed that many places sell Firewrie Harddrives from 40 to 80 gig that include the Firewire card and I was thinking this may be a good road for me to go down... BUT I want to make sure you can capture to the firewire HD. I noticed that the Firewire HD does not look like it can run programs... just store stuff? is this right? so can it capture? I figure that it will either be the best setup possible or it will just be flat out impossible but I need to know before I even think about convincing the wife that I need to spend the money.
I have a 20Gbyte firewire harddisk, and it can be used exactly like an internal harddisk, including running programs off it. I capture video to it using a Dazzle USB device.
I have 80gig firewire hd and it works well. I have noticed
less frames are dropped if I capture to c drive then move though but I only lose about 220 frames in 2 hour show. -
just wondering what kind of access time you have on your drives??? the one I am looking at is 20 gig and has an... average access time: 9ms to 9.5ms thru Firewire 14.2ms, Data transfer rate: Up to 18.5Mb/sec.
as per the specs. as I am new to firewire I just don't know.. are they all going to be the same??
Thanks for the help so far... I definatly will be going this route rather than giving up completely... now I just need to start working on my wife.
matt
Avermedia capture HD using firewire?
By Zachash in forum Capturing and VCRReplies: 3Last Post: 7th Jul 2011, 15:49 -
How can I capture DV without a firewire port?
By alleyman in forum Capturing and VCRReplies: 4Last Post: 19th Jun 2011, 10:51 -
Can I capture with USB 2.0 or does it have to be Firewire?
By sdsumike619 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 7th Feb 2009, 13:19 -
SA 8300HD Firewire Capture
By nebbish_2112 in forum DVB / IPTVReplies: 0Last Post: 30th Nov 2007, 08:15 -
Best Capture from a firewire .
By ZaYoOoD in forum Capturing and VCRReplies: 6Last Post: 25th Nov 2007, 20:41
