I just purchase a Dazzle DVC 80, attached it my comp and ran the s-video and stereo cables to the inputs from my satellite system. I can capture the video, but can't get the audio to work. Im using MGI videowave 4 se, is there a better program I could use instead, and why isn't the audio being captured with the vid. thanks inadvance
System:
1.2 Athon T-bird
512 ram
SB live X-gammer
gefroce2 ultra 64
Windows 2Kpro
I had that same problem as well. I think you have to select the DVC80's inputs from the preferences menu within Videowave 4.
Personally, I would suggest you bypass them entirely and go through your sound card.
Even more to the point, I would suggest you bypass the DVC80 altogether, unless all you intend to do is capture for VCD-bound product. First chance I got, I ditched it for a Studio DC10+. Yeah, you're stuck with just one codec, but it's a small price to pay for being able to output to tape again and to be able to capture at a decent resolution.
How To capture video shot in both sp and lp on the same dvc
By ishwinderjauhar in forum Capturing and VCRReplies: 0Last Post: 13th Jul 2011, 08:40 -
Dumb question on DVC vs HD DV tapes
By arcorob in forum MediaReplies: 4Last Post: 17th Mar 2010, 20:12 -
Dazzle DVC 90 Capturing
By LangleyM in forum Capturing and VCRReplies: 2Last Post: 19th Apr 2009, 09:42 -
Better than Dazzle DVC-170?
By bmbsa in forum Capturing and VCRReplies: 5Last Post: 21st Sep 2008, 06:18 -
Can I load DVC Pro-50 bit
By Tom in HD in forum MacReplies: 2Last Post: 14th Jun 2008, 14:54
