Hi you pros out there,
I'm aware that the size above is not standard DVD, but I'm capturing at this size - and I don't see why I should throw away a large part of the image and downsize to 352 px or waste half the DVD space for 720 px in width! Just where does this crappy 352 px-setting come from?!
I don't have a standalone player and would like to know if any of you folks ever tried this setting on yours? On the PC Zoom Player plays back this file, Nero Recode or Burning ROM doesn't complain about anything "out of standards" (only tried it on the Image Recorder, not a real burn).
The format you mentioned is part of the standard DVD specification and therefore should playback on standalone DVD players.
Look here for a description of the DVD standard https://www.videohelp.com/dvd -
I was going to say....Originally Posted by daveoggy
I don't exactly understand the question being asked here.
352 X 576 is a valid resolution. You are not throwing much away by resizing or cropping from 384 X 576 to 352 X 576.
In short, effectively Full DVD resolution is 704 X 576. 352 is half that. That's where it comes from.If in doubt, Google it. -
Quote: "You are not throwing much away".
There IS a noticeable difference between 352 and 384 px resolution - at least using Avisynth/Lanczos or BicubicResize and CCE at a proper bitrate. Whereas there is (almost) none between a 384 and a 720 px encode on a PC, depending on the DirectShow playback filter - Nero's in my opinion, if it works correctly, is the best. -
The difference is your material won't be playable on most settop DVD players if you use 384.Originally Posted by Zuschauer
IMO if you think there is a bigger difference between resizing 384 to 352 than there is between resizing 384 to 720, then you are doing something wrong I'm afraid.If in doubt, Google it.
Is PAL 576 Higher Resolution Than NTSC 480?
By wulf109 in forum DVD RippingReplies: 12Last Post: 1st Dec 2011, 02:10 -
720 x 576 question
By higgins327 in forum Newbie / General discussionsReplies: 24Last Post: 31st Mar 2011, 15:44 -
dvd plays at 720 x 576 but when ripped goes to 352 x 576 and is squashed
By aljolson in forum Newbie / General discussionsReplies: 12Last Post: 8th Jun 2008, 12:54 -
1440x1080 to PAL SD 720 576 16:9?
By katapulse in forum MacReplies: 3Last Post: 20th May 2008, 05:44 -
Convert .ac3 (384 Kbps) to Dolby 5.1 (448 Kbps) ????
By christopheramos in forum AudioReplies: 6Last Post: 11th Jul 2007, 01:35
