I was thinking about the best configuration to convert VHS to DVD as I'm really picky about the whole quality thing. Anyhow, I just tried a couple of macrovision removers and decided to just go straight for the AVT-8710. Since that's already a TBC would it be overkill to get the JVC DR-M10 DVD Recorder and the JVC HR-S9911U VCR? I think both of those have been known to have TBCs or something like them built in and I don't want to have too much video correction causing a problem. Could I get some opinions on this setup and whether it would be overkill or not?
You can shut down the TBC and probably the DNR filters in the HR-S9911U if you want or need to. The DR-M10SL does not have a way to turn off the pre-encoding TBC/DNR, but the TBC is very mild and the DNR is effective and desirable. Most everyone who uses a TBC-1000 or AVT-8710 in between report no problems.
You need a very high quality VCR to play back VHS with if you want to do a good capture. It makes a really big difference. -
So from the sounds of it I should have no problem with that configuration but the most important part of it would be to get the decent VCR. At least with that VCR I could turn off the filters if there is a problem. Thanks for the info.
Which is better - usb stick vhs cap or hd-pvr cap + convert for vhs to dvd?
By yoda313 in forum Capturing and VCRReplies: 22Last Post: 22nd Dec 2011, 21:13 -
Convert old VHS movie to DVD
By sanray19 in forum Video ConversionReplies: 7Last Post: 20th Oct 2011, 14:32 -
How to convert a PAL VHS into NTSC VHS or DVD?
By coody in forum Video ConversionReplies: 9Last Post: 22nd May 2011, 03:09 -
Help! VHS tape suddenlt decided to stop playing. Some sort of configuration problem..
By stevie P in forum Newbie / General discussionsReplies: 4Last Post: 10th Feb 2010, 14:24 -
Convert DVD to VHS !
By homantam in forum Newbie / General discussionsReplies: 9Last Post: 1st Jul 2007, 02:05
