  1. Hello all,
    I've been making DVDs and VCDs for a while, but I'm still noob in some ways..
    I have a bunch of AVI files I want to put on a VCD. Usually, with all my codecs installed properly, I have no trouble. I wash the AVI through the project settings that I already have in Tmpgenc and make an .MPG and then burn to the VCD. No trouble.
    I have a series in AVI format tho, that is giving me a LOT of trouble. I believe, as the DivX playa reports this, that they are in DIVX video compression format and MP3@128 audio compression format.
    When I encode them in MPG, there is no video., and when I "stop" I get "pointer error."
    VirtualDub, VirtualDubMod both have problems with these files. I've washed them through DivFix and DivRepair, they will barf in VirtualDub and VirtualDubMod.
    I have DIVX installed, XVID and MPEG-4. Does anybody have any idea how to convert these? We're all stumped..
    Thanks in advance,
    -LL2
  2. What does gspot report on these files ?
    If it's wet, drink it
    My DVD Collection
  3. use Procoder, it encodes everything, didn't find a file that won't work
  4. Originally Posted by Hardcoreruss
    Gspot say:
    Video codec: DIVX/XVID DIVX4 - codecs are installed
    Audio codec: 0x0055 MPEG-1 Layer 3 - codecs are installed
    Container: OpenDML (AVI v2.0) Interleave 1 vid frame (42 ms) preload=480 Audio frames: aligned on interleaves
    File length correct
    It also says: User Data/MetaData VirtualDubMod build 1155
    release
