I pulled this from their forum. Hope this helps. Thread here
http://www.supermediaforum.com/showthread.php?t=180
From Roger at Supermediastore:
We have contacted the CEO of Prodisc USA and he confirmed that some Prodisc DVD are using MCC codes. Those MCC codes are supposed to be used for Verbatim branded DVD only but currently they have Verbatim's authorization to use those MCC codes for some Prodisc DVD media. Since MCC coded stampler and dye are made by Mitsubishi Chemical Corporation that company has good reputation in the industry, the discs with MCC codes have the same good quality and compatibility as other discs, probably better. For new shippments coming into USA, he said those discs may still have MCC codes but he can't guarantee that. So in my opinion, if you got MCC coded discs, you are lucky.
Closed Thread
Thanks for the info.
Locking the thread so the discussion can be continued in a single place.
https://www.videohelp.com/forum/viewtopic.php?p=1013776#1013776
Media Info Not seeing all subtitles
By cal_tony in forum SubtitleReplies: 0Last Post: 15th Apr 2012, 23:43 -
Verbatim LTH Media...Info
By New Bee in forum MediaReplies: 2Last Post: 13th Feb 2011, 06:58 -
Media Info query
By Bully9 in forum Newbie / General discussionsReplies: 3Last Post: 7th Feb 2011, 09:54 -
Media Info and AVISynth
By ZedVamp in forum Video ConversionReplies: 0Last Post: 7th Feb 2009, 15:25 -
what do you use to browse file's media info?
By EricG in forum Newbie / General discussionsReplies: 3Last Post: 11th Oct 2007, 19:58
