ok, this is very hard, first, i was reading something about how a to get something to play on a dvd, u need 48000kb of sound, or somehthing like that, anyways, when i put it in the vcd to change to mpg, i cant change the sound from 44100 to 48000, does any1 kno how to change it, cause, after i finished encoding it to mpg, at 99%, it popped up saying, the sound isnt right, so, i dont kno, does it mean something, or, does any1 kno how i can fix it? if u kno, reply, thanks!
S/VCDs only support 44.1kHz audio. DON'T up sample it as all you are doing is losing quality, wasting time, and making a non-compliant disc.
DVD players that are VCD compatible will play standard VCDs as they are.
Regards.
Michael Tam
w: Morsels of Evidence
