I just noticed this today.
I usually don't play back the DVD-RWs that are created by the JVC when I capture video to them because I take them to my PC and re-author with nice menus and burn to DVD-R.
To play the DVD-RW, I have to push the PLAY button.
Is this right?
or did I inadvertently change some setting on the JVC.
The thing is when I put the DVD-RW in my PC's dvd drive, PowerDVD will start playing it automatically.
Mine works the same way, Its not a problem to me. At least it plays! I have two Panasonic dvd recorders that create disks that don't play on most players due to their sytle of authoring.
Remember if it plays with no problem then consider it a success.
One last point, I own a JVC dvd player and it doesn't play automatically on that one either.
whew! glad to read that.
have you yet encountered the other problem I had?
I had a brand new Fuji DVD-RW that I wrote to once or twice. I set it aside. Today, I tried playing it in both the JVC and my LG drive, and both couldn't read it. The JVC said the disc was "unreadable".
any ideas what happened?
I mean 1 out of 5 DVD-RW going bad is not a good ratio. -
I personally haven't experienced that situaton but if the others play with no problems then I wouldn't worry. Due to the fact the other 4 are working tells me nothing is wrong with the JVC.
You could try formating that disk using your computer if it has a dvd writer, this is known to remedy those sort of problems.
my dvd writer shipped with B's Recorder Gold, and I can't figure out how to use it to format a dvd-rw. It has erase....Originally Posted by ejai
I think that this might be the standard way the -RW writers do it. In my Pioneer, I have to press "Play" to play, or "Menu" to see the thumbnails. Personally, I think that is kind of silly, it should just come up to the menu like my LiteOn does it.
TJDLDW 5001, Nov 2003. Pioneer DVR-220-s, May 2004. Haup PVR-250 (2) Ver. 15 + 16. Slowpoke P4 1.8Ghz, 500 gig . Dish DVR-510 - 100 hrs. DirecTV RCA. DLP HD HT Projector at 170 Inches Diag. Tivo Gen. 1 with 180 hours
HOT DEAL: St. Louis Craigslist - $75 JVC DR-M10 DVD Recorder
By jbd5010 in forum Off topicReplies: 2Last Post: 16th Mar 2011, 09:21 -
JVC XV-N480B DVD player won't play on NTSC television
By mike2021 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 8th Jun 2010, 00:39 -
JVC DR-M10 help
By colt4523 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 20th Mar 2008, 07:53 -
How do JVC combo VHS/DVD recorders compare to M10 or M100?
By DGinnetty in forum DVD & Blu-ray RecordersReplies: 7Last Post: 27th Sep 2007, 13:14 -
Media Player Classic won't automatically play the next MPG in a playlist
By dmcmurphy in forum Software PlayingReplies: 0Last Post: 4th Jun 2007, 19:19
