After extracting tracks from dvd's then demuxing the vob's to mpv and ac3 files and then importing into a dvdlab project that dvdlab has problems packetizing some of those ac3 tracks. well after many many different attempts to correct these ac3 problems i found a nice method to ensure that all of your ac3 files are perfect. here goes:
1. extract your dvd's with smart ripper, great program as we all know.
2. use RiverPast Audio Converter http://riverpast.com/ another nice program and add all the vob files into it, export your vob's as wav files into a seperate folder.
3. use a wav normalizing program (if desired) a good one is WavNormalizer http://www.linearteam.dk and you can batch process all wav's at one time into a seperate folder.
4. open dvdlab and drop your vob files into the assets bin and let them demux. it will create the mpv files as well as ac3 files, go back to the original folder were they demuxed and delete ALL the ac3 files 'cause you won't need them.
5. open a program called ffmpegGUI and you can now convert all of your nicely normalized wav into perfect ac3 files!
6. now you have all the mpv and ac3 files to throw into dvdlab without any problems.
i hope this helps some of you out there! it works great for me...![]()
Just a warning; the free AC3 encoder tools aren't 100% compliant; they may make slightly invalid AC3 audio that fails to play in some (esp. Pioneer) players.
How to Author AC3 5.1 Channel Audio Only DVD Using DVDLab Pro 2
By Hittz in forum User guidesReplies: 10Last Post: 3rd Apr 2011, 01:05 -
Avi to Ac3 user guide. How to encode the audio from an avi to ac3 .
By freebird73717 in forum User guidesReplies: 5Last Post: 9th Dec 2009, 22:53 -
How to convert AVI/DivX/XviD with AC3 to DVD with AC3
By Baldrick in forum User guidesReplies: 52Last Post: 21st May 2008, 20:22 -
Sync issues after converting AVI (DivX 5/AC3) to MPEG2/AC3
By Greycat in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 11:24 -
H264 + AC3 + AC3 --> VOB - What is wrong with my command line?
By olik in forum ffmpegX general discussionReplies: 5Last Post: 3rd Feb 2008, 08:06
