hi all,
i know SP2 is due to be released soon but i was thinking to reboot my pc before installed this update via CD. My query is this, do i need to install SP1a prior to installing SP2? or not, logic says yes but i just want to get a professional opinion by you guys, thanks.
kas
Results 1 to 21 of 21
yes service pack 1 does need to be installed first. I would do a complete system backup b/4 installing sp2. or at least backup critical data.
No, you can just install sp2.
Sp2 has all of the updates of sp1 included. -
No problem.
I have installed sp2 on a computer without sp1 so I know what I am talking about. -
AnonymousGuest
might want to check this thread out first.
https://www.videohelp.com/forum/viewtopic.php?t=234328 -
The only minor problem I had was with Xolox.
I had to reinstall it.
Other than that, not a problem. -
what do the service packs actually do anyway? ive never gotten them, but i did find this, which kinda gets me concerned about getting it
http://support.microsoft.com/default.aspx?kbid=884130&product=windowsxpsp2 -
It beefs up the firewall which is now called windows firewall.
The firewall still does not block outbound information.
There is a security center which monitors your computer and tells you when you need to download antivirus defenition updates and lets you know if you are up to date on your windows updates.
There is a feature called Data Execution Prevention(Dep).
A built in popup blocker for IE6, and a bunch of security fixes..... -
The windows firewall is now turned off by default.
Sp2 has all of the patches of sp1 as well.
It turns programs like messenger by default.
It also has improved wireless support. -
I have SP2 on 2 machines so far and no problems. One already had SP1 and the other was a clean install of XP.
The security add ons can be a little irritating, but I haven't bothered to configure them completely yet. I left the firewall on and it seems to coexist with my router firewall without any major problems.
One thing is nice; You go to Microsoft to see if there are any updates needed and it says no. This probably won't last long, but so far so good.
I used the beta version a month or so ago and I wouldn't recommend it. Go to MS or mirror and get the final release and save yourself some problems. -
I have installed it on 4 computers.
On my two, I turned off the security center.
I do the updates myself. -
Yes it wasOriginally Posted by gitreel
We're Hyperthreading.
Nothing can stop me now, 'cause I don't care anymore.
Downgrading from XP SP3 to SP2?
By Super Warrior in forum ComputerReplies: 11Last Post: 5th Feb 2009, 16:47 -
Vista SP2
By wtsinnc in forum ComputerReplies: 2Last Post: 13th Oct 2008, 13:09 -
encoding with CCEnc Sp2
By burgkev in forum Video ConversionReplies: 1Last Post: 28th Aug 2008, 20:38 -
WMVA codec without XP SP2?
By Sephiroth666 in forum Software PlayingReplies: 8Last Post: 3rd Jul 2008, 19:09 -
CCE-SP2
By Belfour in forum DVD RippingReplies: 10Last Post: 29th Sep 2007, 20:47
