I have a Fuji DVD-RW which I used in the JVC once or twice.
I set aside and haven't done anything to it.
Today when I tried to play it in both the JVC and my PC's DVD drive, it wouldn't play.
Is there anyway I can rescue the data that is on the disK?
I don't understand how it can go bad like this. I only used it twice at most. It's a Fuji made by TY.
Can anyone shed any light on what happened?
Results 1 to 11 of 11
Out of curiosity is this from a normal standalone dvd player hooked up to your tv ?
I believe before it can be red in your pc you will need to close the session on the standalone.
I am sorry I cannot offer anymore information on the standalone side as I do not have one. -
I did finalize the DVD-RW. It worked before, and now it doesn't.
I'm just really surprised 1 out of 4-5 DVD-RW has gone bad like this.
Thank goodness I bought a 120GB hard drive as back up. -
Does the dvd read in explorer ?
This happened to a TDK -RW recorded in -Video mode on my Pioneer. It has only happened once. The Pioneer "couldn't" format it, so I took it to my Sony +- writer on the PC, did a full format, and it has worked great ever since. Maybe I had a spec of dust in just the wrong place..
TJDLDW 5001, Nov 2003. Pioneer DVR-220-s, May 2004. Haup PVR-250 (2) Ver. 15 + 16. Slowpoke P4 1.8Ghz, 500 gig . Dish DVR-510 - 100 hrs. DirecTV RCA. DLP HD HT Projector at 170 Inches Diag. Tivo Gen. 1 with 180 hours -
what software did you use to do a full format?
my LG drive came with PowerProducer and B's Recorder Gold, and I can't find anything with either software to format my DVD-RW
help! -
Originally Posted by Hardcoreruss
wish I knew how to do a format on my LG dvd drive -
I am sure problem lies in the faxt you are going from a standalone unit to your pc.
I use Sonic's Record Now DX. It came with both my Liteon 411s and Sony burners. They don't seem to have a demo.
You could always go to www.nero.com and download Nero 6 Ultra Edition. That will have similar (and better) control over burning. I believe it's a 30 day trial, with the option to register.
Nero is the de-fact-o standard. Give it a whirl.
Inaccessible folders on hard drive. Need to reach them
By wan2no in forum ComputerReplies: 6Last Post: 14th Nov 2007, 14:01
