ive come across a couple of films lately where the Programe doesnt stop as though it cannot process the files But just doesnt finish editing .. it produces the mpeg files from the bins but just sticks on demuxing . at first I thought it was being temp but it has happened again on a comp difff film ...
When I ripped the mpegs out of the bin file (I thought id try a diff method just to make sure) when trying to join the 2 mpegs together tmpeg came up saying that there was no recognised audio file in either of the mpegs but they played with no problems through WMP and Winamp so whats the score is it something specifical linked to these 2 films ie the mpegs or is it a fault in the programe itself ... I must say that I have done hundreds of films using this programe and it is the mutts nutts
on another note is it worth upgrading to the latest rls ? Im using the adage if it aint broke dont fix it but u never know
your comments or advice would be appreciated
Sounds like there is something wrong with those mpegs. Probably have to re-encode them over in tempeg if possible. There is a sticky thread about some fix using womble without have to reencode to fix sync problems with audio. But it sounds like there is something wrong with the mpeg file. If tempeg does not let you reecode since it does not recognize any audio file then there is something wacked out on those files.. I would imagine.
I just registered and am using the lastest SVCD2DVD v1.51.20 and it seems very stable. Chrissyboy says he only supports the lastest build. I would advise to upgrade at any rate. I think this program gets better with each build. I have made about 5 movies with only one that was out of sync... and that was not SVCD2dvd's fault.
Just because it plays in MP does not mean anything. The audio track may be in another format. I believe I read that svcd2dvd does not support AC3 sound yet. My guess is that the only chance you will have to build those into dvdmpegs is to find some app that will re-encode those files.. a time consuming process.
New Poll Ideas
By tgpo in forum PollsReplies: 515Last Post: 9th Oct 2015, 06:16 -
Which adobe programe is good?
By Seasonal in forum Off topicReplies: 2Last Post: 29th Dec 2011, 19:16 -
Edit on an average 2 core laptop, a 7 minute programe that will go online
By persephone in forum EditingReplies: 14Last Post: 9th Dec 2010, 15:03 -
Will Only Convert Half Of Film And Stops
By Teac23 in forum Video ConversionReplies: 2Last Post: 18th Apr 2010, 09:59 -
Newbie looking for ideas..
By HaleC. in forum Newbie / General discussionsReplies: 8Last Post: 10th Jul 2008, 13:37
